"Display the attribute dialog before storing new features" bypasses FeatureInspector
1381
07-02-2010 03:19 AM
by Anonymous User
Not applicable
Original User: r_pankevicius
If the user set in Editing Options (accessed from standard Editor toolbar) in Attributes tab that he/she wants to "Display the attribute dialog before storing new features" ArcMap displays standard ArcMap attribute window in a modal dialog.
If target feature class has a class extension registered and implemented IObjectInspector control the expected bahaviour is a customized attributes dialog, not a standard one. It's inconsistent as user sees customized attributes page for existing features but a standard one for new features.
See attached picture: 2 different attributes windows are shown at the same time: point with OBJECTID=2 is shown using Attributes toolbar button (modeless customized dialog).  point with OBJECTID=3 is popped up after user just created a new point using Sketch tool.
I reproduced this by using Tabbed feature inspector C# sample: http://edndoc.esri.com/arcobjects/9.2/NET/FBB894AD-16DF-4FAD-82F6-F0CA13B5BE7D.htm
Data file with point feature class with correct class extension is attached (TfiSample.gdb.zip) so you can delete AddEXTCLSID command from solution.
Anyone knows how to solve this problem?
Platform: ArcMap 9.3, WinXP. (But works same odd way on ArcGIS 10 too.)
by Anonymous User
Not applicable
PS. ESRI support suggested to implement additional interface IExtendedObjectInspector. This worked to solve the problem. I love that ArcObjects wood of interfaces 🙂
