Add-In Version Not Match & ArcMap crashed
1697
05-10-2017 10:43 AM
ShaningYu
Honored Contributor
I created an Add-Ins App using VS2012, FW4.5.  It works well on ArcMap 10.2 of my CPU.  However it does not work when it is loaded on other 2 CPUs.
In one of CPUs, ArcGIS 10.2 (same version as my one), clicking the Add-In icon leads to the close of the ArcMap.
In another CPU in which ArcGIS 10.4 Desktop is used.  After clicking on the tool icon, an error message pops out: "Add-In Version Not Match".  From the thread  Error: No GUI components found in this Add-In. Add-In version does not match , I checked the Config.esriaddinx file, in which
  <Targets>
    <Target name="Desktop" version="10.2" />
  </Targets>
Will the 10.2 be the problem of "Version Not Matched"?
Thanks if you can share your experience.
ShaningYu
Honored Contributor
It was found that this problem was due to the crashed SDE DB.  After re-building the DB and creation of the version, the problem was gone.  Thanks for your review.
