Add-in Command Container Templaet
1153
08-29-2012 09:17 AM
MaryEllen_Perko
Can anyone tell me where I can find Esri version 10 add-in templates for Visual Studio 2010?  In my reading, I understand that they should be installed with the ArcObjects .NET SDK.  Unfortunately, I didn't do the install so don't know if something was missed, but I only see four add-ins which indicates that something was installed correctly - ArcCatalog Add-in, ArcMap Add-in, ArcScene Add-in, and ArcGlobe-Add-in.
In particular, I need the "Add-in Command Container."
Any help is appreciated.
Mary Ellen
QinyuePan
Have solved this problem yet?
I encountered the same thing!
JohnHauck
Only some types are available from the initial Project and Add-In Wizard. After you have created the project open the Solution Explorer and right-click the project > Add > New Item... From the Add New Item dialog go to ArcGIS\Desktop Add-Ins and select Add-In Command Container. Then you will see a wizard that will help you define the properties for the command container.
