Add-in Command Bars option missing when adding a Add-in Component
4928
5
09-25-2012 07:29 AM
HalilSiddique
I have just installed ArcGIS Desktop 10.1, and am trying to create a new toolbar, from the notes I have from the training course I went on, it says to
Add new Item (Selecting Desktop Addin's)
Click Add
Choose Add-in Command Bars...
My problem is that the Add-in Command bars option is not there, I can only see Add-in Components s. See attached picture.
Anyone got any ideas on this?
KenBuja
MVP Esteemed Contributor
When you click on New Item, make sure you select the Add-in Command Container instead of Add-in Component.
[ATTACH=CONFIG]18003[/ATTACH]
KenBuja
HalilSiddique
Thanks Ken!
shay-geo
This is relatively old thread.
But i have a different issue that i can't see Command Bars when i Add New Project -> ArcGIS -> Desktop Add-Ins
I don't see Add-in Command Container or Add-in Component. Instead i am seeing the one in screenshot below.
[ATTACH=CONFIG]20382[/ATTACH]
After i click "OK" to create new project, i see options as shown in the screenshot below.
[ATTACH=CONFIG]20383[/ATTACH]
I am using ArcMap 10.1 with Visual Studio 2010 and .net framework 4.0.
Thanks in Advance,
Shailesh Gavathe
KenBuja
It should be the same issue. You will see those options when you use the Project|Add New Item menu selection after you've created your project.
shay-geo
Indeed Ken,  It's the same issue.
Thank you for pointing me in right directions.
Thanks and Regards,
Shay
