Activating the rotation tool on Editor Toolbar
1092
07-25-2013 03:25 AM
SajidAli2
I have added the rotate tool from graphics element on the toolbar but it is not getting activated at all.
I have tried it even after starting the edit session but still it is not getting activated.
How can i get it activated so that it becomes usable.?
Thanks in Advance
Sajid
BarbaraSchneider1
Hi Sajid,
you can only rotate graphic elements using this rotate tool. In an edit session, you are changing features, not graphics.
Barbara
FreddieGibson
Honored Contributor
Are you referring to the Rotate tool from the Page Layout section in the customize window? If not, could you further describe the tool you're using?
