Accessing ArcGIS Geoprocessing Service with Security .NET
982
06-09-2011 08:07 AM
MeleKoneya
I have published a Toolbox to ArcGIS Server as a geoprocessing service and am trying to access the service via .NET.    I get an error message telling me the job has failed after running the following code:
Geoprocessor gp = new Geoprocessor();
gp.AddToolbox(@"http://vmascgis01/arcgis/services;PrintLISMap");
                     gp.OverwriteOutput = true;
            IVariantArray parameters = new VarArrayClass();
            parameters.Add(@"D:\workspace\Temp\Untitled.mxd");
            parameters.Add(@"D:\workspace\Temp\Base_Map.lyr");
            parameters.Add(@"D:\workspace\Temp\new.mxd");
            IGeoProcessorResult result;
            result = (IGeoProcessorResult)gp.Execute("AddLayerToMap", parameters, null);
The ArcGIS Server has ArcGIS Server security in place and this looks like the problem because if I access the toolbox directly via its location on disk, the code works.
How do I pass credentials to an ArcGIS Server Geoprocessing Service?
LeoDonahue
Does the SOM and SOC have access to D:\workspace\Temp ?
Do the users, assigned by ArcGIS Server security, have access to that directory?
Didn't you have to connect to the ArcGIS Server already using impersonation?  Such as:
http://edndoc.esri.com/arcobjects/9.2/NET_Server_Doc/developer/ArcGIS/ArcObjects/connect_gis_server....
