Access Violation when creating MOLE Symbology in ArcGlobe 10.1
860
08-07-2012 12:44 PM
BryanKardisco
Transitioning from 10.0 to 10.1 and creating MOLE symbology in ArcGlobe - the application crashes at the following line of code
Globe.AddLayerType(graphicsLayer.GlobeGraphicsLayer as ILayer , esriGlobeLayerType.esriGlobeLayerTypeUnknown, false);
Leading up to this I do the following:
I have a custom class called 3DDataLayer which has the following properties:  IForceElementLayer (named MoleLayer) , IGlobeGraphicsLayer (named GlobeGraphicsLayer) and other properties that aren't relevant.
The first thing I do is create a workspace by doing the following
IFeatureWorkspace featureWorkspace;
myWorkspace = myWorkspaceFactory.CreateNewScratchWorkspace();
featureWorkspace = myWorkspace as IFeatureWorkspace;
myFields = new FieldsClass();
//... // Setting my field names and alianses and properties
featureWorkspace.CreateFeatureClass(inName, myFields,  null  , null , esriFeatureType.esriFTSimple , "Shape" , String.Empty);
//Create a mole layer
I create the mole layer as follows
IFeatureClass featureClass = LoadFeatureClass(inName);
IGeofeatureLayer featureLayer = new FeatureLayer() as IGeofeatureLayer;
featureLayer.FeatureClass = featureClass;
ICachedGraphicFeatureLayer moleLayer = new ForceElementLayer() as ICachedGraphicFeatureLayer;
moleLayer.FeatureLayer = featureLayer;
//Set properties such as size / 3d settings /
ILayer layer = moleLayer as ILayer;
layer.Name = inName;
Globe.AddLayerType(layer , esriGlobeLayerType.esriGlobeLayerTypeDraped, false);
myMoleFeatureClass = featureClass;
Any ideas why this is blowing up?  I need this so I can turn on Military Symbology based upon certain trigger conditions.
BryanKardisco
After looking online a bit it looks like the issue is resolving from loading a Feature Class from an existing GeoDatabase (GDB).
Is this something others have seen?
I need this ability to create MOLE Symbology and be able to switch back between MOLE Symbology and generic graphics that I draw when not enabling said symbology.
