Access Connection Properties of SDE Standalone Table
1154
06-11-2013 07:32 AM
MichaelVolz
Esteemed Contributor
To All ArcObjects Developers:
I am writing an Add_In to change the properties of a standalone SDE table in ArcMap.
I have the following code that I thought would get the connection properties, but it keeps crashing the Add-In.
pStndAloneTbl = pTableColl.StandaloneTable(k)
'Instantiate the property set object
pPropset = New PropertySet
pDataLayer2 = pStndAloneTbl
pDatasetName2 = pDataLayer2.DataSourceName
pWorkSpaceName2 = pDatasetName2.WorkspaceName
pPropset = pWorkSpaceName2.ConnectionProperties
The code crashes at pDatasetName2 = pDataLayer2.DataSourceName even though Intellisense tells me that the DataSourceName
method is available from the pDataLayer2 object.
Can anyone please tell me what I am doing wrong here as it seems to me like this code should work?
Any help or hints are greatly appreciated.
NeilClemmons
Honored Contributor
Try getting the connection properties from the table's workspace:
Dim table As ITable = standAloneTable.Table
Dim dataset As IDataset = DirectCast(table, IDataset)
Dim workspace As IWorkspace = dataset.Workspace
Dim props As IPropertySet = workspace.ConnectionProperties
MichaelVolz
Thank you Neil, but the last line of your suggestion when used with Intellisense does not expose the ConnectionProperties object.
Update:
Your code did work.  I changed Workspace to Workspace2 assuming that Workspace2 was the same but just exposed additional properties.  But Workspace2 exposes less properties which include ConnectionProperties.  Once I changed it to Workspace I was able to access ConnectionProperties.
