Vertical cooridnate system not getting removed from featureclasses inside featuredataset even after clearing.
756
03-20-2023 02:31 AM
Labels (3)
ptj
Hi All
Facing below issue - not sure if its a product bug or if there is something which we are doing wrong.
Once vertical coordinate system is applied to featuredataset and then if removed – it does not get removed from featureclasses inside featuredataset.
We tried below but it did not produce expected result :
  1. Removed the Vertical coordinate system by clicking on clear – in ArcCatalog , it shows the Vertical Coordinate system cleared in featuredataset and featureclasses but after refreshing the connection the VCoord comes up again.
  2. Unregistered the dataset as versioned and then removed the Z coordinate from the dataset, by which the coordinate gets removed from the FC's also but after reconnecting to the Database the Z coordinates are seen back again in the FC's.
  3. Cleared ArcMap Cache- still issue persists.
If anyone knows any workaround - please let me know. Thanks in advance.
BR
Poonam
