Use of Concurrent license along with single use extension
654
12-11-2025 01:06 AM
MalharKaleindia
Hello Everyone,  our desktop application is authorized from License Manager (Concurrent) use and my extensions are single use. When I test, I can use either the core license or the extensions license.
I am unable to find any Esri Documentation which explicitly say that we need to have the extension type same as the core application.
Let me know if this is an expected behavior.
Thanks in Advance
Malhar
ClioClark
Hi Malhar,
You cannot mix single-use and concurrent use licenses, you must use one or the other. If you are using a concurrent use ArcMap license, ArcMap will be looking for licenses on your license manager. See the following documentation:
https://desktop.arcgis.com/en/arcmap/latest/extensions/main/using-extensions-in-arcgis.htm#:~:text=I....
Hope this helps!
ClioClark
Hi Malhar,
Hope this helps!
MalharKaleindia
Thank you @ClioClark for sharing the documentation.
