Turn on label with arcpy to create script tool
1172
06-23-2022 01:33 AM
AlexandruBârsan
Hi! I want to create a script tool that will start the label for certain layers, that is to add the parameters with the layer to which I want to activate the label and what field I want to display it that I need.. I used this script
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
layer = arcpy.mapping.ListLayers(mxd, "")[0]
if layer.supports("LABELCLASSES"):
for lblclass in layer.labelClasses:
lblclass.showClassLabels = True
lblclass.expression = " [Layer]"
layer.showLabels = True
arcpy.RefreshActiveView()
but it doesn't work to create a script tool, it only works in python windows. Do you have any suggestions?
Tags (3)
DuncanHornby
MVP Notable Contributor
You need to read the help file and understand how to turn your script into a script tool. Its all in the help file here.
