Trasformation method problems
612
12-13-2024 02:30 AM
GSala
Hi
I'm having an issue with the transformation methods in ArcMap. When I try to transform a coordinate system to another, I cannot select any transformation method.
I attempted to transform Monte Mario Italy 1 to WGS1984 UTM 32N (which has a different datum), but no options are available, even though they usually are. However, if I try the same process on another computer, I don't encounter this problem.
