Raster dataset into SQL Server 2017 Enterprise Geodatabase
7340
12
01-25-2019 02:45 AM
Pieterdu_Plooy2
Hi guys
I am trying to import a raster dataset into an SQL Server 2017 enterprise geodatabase. (Arc 10.6.1)
I am getting errors as can be seen in the attached file.
Any help would be appreciated
LanceCole
I would definitely call Esri Support or put a support ticket in to get a quick reply to this issue.
Pieterdu_Plooy2
Just another question.  Did you install any other patches?
LanceCole
ArcGIS Desktop 10.6.1 v10.6.9270
   ArcGIS Desktop 10.6.1 Raster Patch (ArcGIS-1061-DT-R-Patch)
I may have also installed ArcGIS Coordinate Systems Data but cannot recall if that was before or after I tested the issue.
You can run this tool Patch Finder for ArcGIS to get a list of installed patches on your system to confirm it is installed.
