Query layer to show two tables as one
4757
10
11-02-2021 08:21 AM
DougBrowning
MVP Esteemed Contributor
I am trying to make a query layer that shows two tables in one.  Both tables have the exact same schema.  It is not a join, just want to show the two tables like they are one to the user.  They are in the same SDE.
In SQL I can just do this
SELECT * FROM [ilPub].[PubDBO].[TERRA], [ilPub].[PubDBO].[LMF]
In ArcMap I get a ambiguous name objectid error.  I have done a ton of searching but only finding joins.
thanks
DougBrowning
Just straight union if the schemas are the same, and they must be.  If not add a field list to make them the same.  Also it must have a ObjectID field.  If versioned make sure to use the views.
select * from Pub.PubDBO.Terr_evw UNION ALL select * from Pub.PubDBO.LMF_evw
hope that helps
