Population clustering from Raster using SUM of pixel value
942
09-10-2023 09:14 PM
SahanSankalpa
Hi All,
I have a raster image with different pixel values, each one representing the number of people living in the pixel. I want to cluster the pixels based on the sum of the pixel values equaling 1000 in each cluster. I do not expect an exact sum for each cluster, but I aim for the sum value to be close to 1000. I have tried using a vector point format and then converted it into raster format to experiment with this approach.
I have converted the vector points into a raster and assigned the attribute data to the pixels. As a result, the raster only contains pixels where there were originally points."
I am using ArcMap 10.7.
I am also fine with vector based cluster for this as well.
Tags (3)
