ModelBuilder - Clip - discard
1620
03-20-2021 03:34 AM
Labels (2)
StanislavaV
Hi, guys,
is there any solution for workaround in ArcMap with Basic license for Clip - discard in ModelBuilder?
Thank you.
DavidPike
MVP Notable Contributor
If you mean a workaround for the Cut or Erase tool without the required license, there's a workflow listed here - How To: Remove overlapping areas of a polygon without using the Erase tool (esri.com)
As to modelbuilder, I'd test this workflow then chain it to your model,  also recommend you utilise the in_memory workspace or scratch GDB to reduce intermediate data creation.
DavidPike
StanislavaV
thanks!
