How do I compare two rasters based on pixel value?
2732
08-08-2022 11:34 AM
Labels (2)
EllieHakariAK
What I want to do is take the 2010-2019 and 2040-2049 rasters here and create a new layer that highlights only pixels where the value rises above freezing (0°C) between them. The end result will show where we can expect permafrost to thaw in the next 20-ish years in Alaska.
I've worked with rasters only a handful of times, so I feel a bit out of my element here. Are there any tools, equations, etc. for accomplishing this?
DanPatterson
("2040-2049" - "2010-2019) >= 0
Would give you a boolean mask where the above is true (1) or false (0)
You can do this in the Raster Calulator
... sort of retired...
EllieHakariAK
Hello Dan! Thank you for the suggestion. I attempted to perform the calculation, but I received the following error:
ERROR 000539: Error running expression: rcexec()
File "<expression>", line 1, in <module>
File "<string>", line 8, in rcexec
RuntimeError: ERROR 010240: Could not save raster dataset to 2010_2040 with output format GRID.
Failed to execute (RasterCalculator).
I'm not sure why it would be throwing this error. Any ideas?
DanPatterson
save it as a tiff in a folder, which is the preferred raster format
eg  c:/your_folder/rast_2010_2040.tif
GRID's cant begin with numbers and there a whole load of other restrictions
DanPatterson
fixed?
