Find and replace unicode characters
2041
02-18-2021 02:33 AM
SimonCrutchley
I have a macro, built by a developer, but it fails when processing some of my files because they have unicode characters. Is there a simple way to search through my feature class to find and replace all of these. For some it has come up with a specific reference e.g. 2013, so I've just done a find and replace, but others have come back just with xc2, which is too vague.
I hope that makes sense. As you can see I'm not a programmer.
Thanks
Tags (1)
DanPatterson
MVP Esteemed Contributor
To get you started see my link here
Solved: replace accented characters with the field calcula... - GeoNet, The Esri Community
and the link within it.
Since you haven't specified what exactly you want to replace and keep
''.join([i if ord(i) < 128 else ' ' for i in text])
this will replace characters with a space
As in this example
s='ABC马克def'
''.join([i if ord(i) < 128 else ' ' for i in s])
'ABC  def'
from this link python - Replace non-ASCII characters with a single space - Stack Overflow
... sort of retired...
gunturhakim
Hi dan,
oke I will try to follow of that from that link
mampangbest regards
