Creating and saving a DEM TIF file from a Resampled file
1671
05-13-2024 05:43 AM
AmirFarshadfar
Hi
I have a question. I have a DEM file with resolution 15 cm and I want to change it to 4 m resolution. I check out some of the website and they introduced that I should select in the “Arc toolbox” as following:
Data Management Tools – Raster – Raster Processing – Resampling
And from here I changed the resolution X and Y to 4m * 4m
When the file is created I select the “File” menu tab and select “Export map” and then save the file as TIF.
In this time, when I want to use the Global Mapper software to read the elevation data as a DEM file from it (like what I was doing with the original DEM 15 cm resolution file data and I read all of the elevation data from it before), it seems the resampled file data is not completely saved as a DEM TIF data file and it seems it has some problem for opening the file.
Could you let me know how could I save a Resampled file as TIF file that I could use it in other software to work with that and read the elevation data from that?
Thanks for your response
Sincerely
Amir Farshadfar
Tags (3)
