Changing how to open a .dbf file
3970
09-02-2020 11:41 AM
SLouq
by MVP Alum
I exported a feature out to a shapefile and I was trying to open a .dbf file in Excel to calculate a value and somehow when I right clicked on the .dbf in Windows Explorer and went to 'Open With' it changed the application used to open a .dbf file to Adobe Acrobat. Can anybody tell me where I can go to change the Open with option to 'dbase'
Thanks
JoeBorgione
see if this helps you:  Using Office 365, Windows 10; How to use 'Open With' to - Microsoft Community
That should just about do it....
SLouq
by MVP Alum
Thanks for the reply Joe!
What is mentioned in that article is exactly what I did but somehow the .shp portion of the shapefile export changed the Open With to ArcGIS Pro and I want it back to what it originally was.
See my insert
Example
