Can't load attribute assistant?
1244
09-03-2020 08:43 AM
FredSpataro
Hi All,
I've downloaded the latest version of the attribute assistant from here:
Attribute Assistant | ArcGIS Solutions
Requirements says: ArcMap (Standard or Advanced) 10.2.1, 10.5 - 10.8
I'm running:
I get the following error:
I've tried running ArcMap 'as administrator'... same result.
Any ideas?
Thanks
Fred
FredSpataro
Just in case anyone else runs across this ... apparently you can't add the extension via the 'Addin Manager/Customize' dialog.
Just double-click/execute the add-in with all the arcgis apps closed.  As per the doc:
Install add-in - Attribute Assistant | ArcGIS Solutions
RTFM ..
