ArcMap Python Security Concerns
4539
9
09-09-2021 01:37 PM
AliceWilson
We have several who still use ArcMap Desktop - we have all upgraded to 10.8.1. Our IT Dept. recently reached out to us as they discovered the security issues with the python version that comes in the arcmap build/install of 2.7.18 this is what shows up. How are you to continue to use ArcMap with a security risk that there doesn't seems to be a fix for.
105878
EOL/Obsolete Software: Python 2.7.x Detected
24
The system is at high risk of being exposed to security vulnerabilities. Since the vendor no longer provides updates; obsolete software is more vulnerable to viruses and other attacks.
JoeBorgione
That's a great question!  The short answer is something along the lines of; you don't. The security risk is always going to be a problem, and if you think about, it's been there for years.
Python 2.x is old school as opposed to the later 3.x releases and has limited shelf life at best.  My agency abandoned ArcMap/ArcCatalog a couple years ago.  I don't miss it at all.
That should just about do it....
curtvprice
I think we are wired differently. I still miss workstation. RESELECT with KEYFILE, PROGRAM SECTION EVEN.
AML Forever. 😉
JoeBorgione
I used weave Perl into AMLs.  Pretty cool, back then.
But ArcGIS Pro and Python 3.x is my story now, and I'm stickin' to it!
DanPatterson
MVP Esteemed Contributor
python 2.7 continues to be patched with security updates... if they are feasible.
That warning is just that.  The software is End of Life (but that hasn't stopped some of us from still being in this Community 😉 )
Having said that, dump arcmap, there is no reason to keep it going since people have had since 2015 to adapt to the newer technology.
python 2.7 is 10+ years old. Python is at version 3.10, although Pro toddles along at 3.7.
AML... and Avenue, now that was worth keeping
... sort of retired...
curtvprice
I have a button I wear at the UC sometime: "My AML from 1996 still works."
JoeBorgione
@DanPatterson -
Even if 2.7 got patched, would that not require a new install of the patched version?  And how does anyone know when it's been patched?  And what has been patched patched?
Couldn't agree more!
DanPatterson
manual install... patching date would be noted on the floppy disk
JoeBorgione
You’re killing me, Patterson!
The OP is wondering ‘Who are these guys and why can’t I get straight answer out of them?’
JoeBorgione
