ArcMap Output UTM as 3 fields
1317
03-01-2022 08:33 AM
Labels (3)
BeckB
I'm using ArcMap 10.8.1. I have coordinates of points in decimal degrees, which I would like to convert to UTM and ultimately output to Excel. Since I want to output the coordinates to Excel, I'd like to have the UTM zone, easting, and northing as three separate fields. Is there a way to do this? I know the Convert Coordinate Notation tool can do the conversion, but it outputs the coordinates as one field.
JayantaPoddar
MVP Alum
After projecting your data to UTM (assuming the points belong to a single UTM zone), you may use Add Geometry Attributes (Data Management)—ArcMap | Documentation (arcgis.com) and Calculate UTM Zone (Cartography)—ArcMap | Documentation (arcgis.com) (Add a Text Field "UTM_Zone" to the attribute table before running this tool).
Think Location
