ArcMap crash when intersecting a buffer polygon feature with a watershed polygon
2596
04-08-2020 01:32 PM
by Anonymous User
Not applicable
I tried to run a python script that is intersecting a stream buffer polygon with a watershed polygon and it crashed on the same watershed ID twice. Same thing happens when doing the same thing in ArcMap using model builder. ArcMap crashes without an error. Nothing appears out of the ordinary when I look at these two polygons in a map. I've successfully done this process with other stream buffers and watersheds from the same data sets. It just doesn't like watershed #139.
Appreciate any suggestions....
Pam
KoryKramer
Esri Community Moderator
Check and repair geometry if needed.
Check Geometry—Help | Documentation
If you send the .dmp file from C:\Users\<user>\AppData\Local\ESRI\ErrorReports we can analyze it to see if it provides any clues.  You can either attach it or send to [email protected].
KoryKramer
by Anonymous User
Not applicable
Thanks Kory - I was able to get the model to work in ArcMap and the script to work by adding a Repair Geometry process.
Thank you!
Pam
MichaelVolz
Esteemed Contributor
Pro has an additional geometry check I believe called OGC which was able to detect errors that the ESRI geometry check was unable to find.  Just a suggestion if you have access to Pro.
by Anonymous User
Not applicable
Thanks Michael - I will keep this in mind if I ever need it!
Pam
