Add-in folder path not saving in ArcMap 10.2.1
610
05-31-2020 11:05 PM
DebanjanChatterjee
I have added add-in folder path (local C: drive) with in ArcMap. Save the MXD. Re-open the MXD, the folder path is missing.
System: Windows Server 2012 R2 Datacenter
I have checked, the AddInFolderLists.xml is not generating in C:/Users/<<user>>/AppData/Roaming/ESRI/Desktop10.2 folder. The file gets generated/updated when add-in folder is added using ArcCatalog.
Tags (1)
