where to change the background color for a customized widget?
1932
10-27-2016 10:12 AM
Alexwang
HELLO, can anybody tell me where to change the background color for a customized widget I built? Thanks,
Tags (1)
Alexwang
Thanks Robert for your response. I have attached a screen shot. I used Lauchpad theme and I want to change the default white background color to other color.
RobertScheitlin__GISP
Alex,
   that is a very subjective question... Is your widget using a tab container? What theme are you using? Probably would be better to attach a screenshot pointing to exactly what you are trying to change color for.
Alexwang
Alex,
  Add this css rule to your [install dir]\server\apps\[app#]\themes\LaunchpadTheme\common.css
.jimu-panel.jimu-launchpad-panel {
  background-color: blue;
Alexwang
Worked, always! Thanks, Robert.
