where is the analysis widget in web-app-builder 1.1?
3588
05-01-2015 02:30 PM
SteveStearns
We have an Enterprise Portal running the 10.3.0 suite of ESRI products.  I just downloaded the version 1.1 upgrade of WebAppBuilder and I do not see the new Analysis widget that is mentioned in the documentation.  Is this feature not available against an enterprise portal, or perhaps requires a greater version?
RobertScheitlin__GISP
Steve,
   Yes, that is correct anything that is new to 1.1 of WAB will not be included in the Portal version of WAB until 10.3.1.
Steve,
   The WAB that comes with Portal at 10.3 is actually the 1.0 version of WAB. You will not have the analysis widget until 10.3.1 in a couple of months.
SteveStearns
So, the developers' edition of WAB 1.1, which has the Analysis Widget in its sitemap directory, will not show the widget until I (the administrator) update the Enterprise Portal to version 10.3.1 ?   Are there similar limitations on the other new widgets (swipe tool, time tool)?
Steve,
