Webapp builder Attribute table Lat/Long
1244
08-05-2021 10:44 AM
AaronNash__GISP
There is a logged bug with the attribute table in web app builder. I am trying to calculate lat and long using an arcade expression. The coordinates show up in the popup window but it crashes the attribute table causing the data not too load. I have tried with smaller datasets and get the same issue, has anyone been able to find a workaround or alternative solution. We would like to export to csv and have lat and long in the export.
thanks in advance.
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzMTk1OQ==
BUG-000131959
suburbanMapper
Commenting here because I am experiencing the same issue.
Did you find a resolution or work-around? Appears the bug is still unresolved.
AaronNash__GISP
unfortunately not, ended up adding lat and long into the feature class as fields and using the smart widget to keep it updated.
