The Dart Theme uses:
.jimu-widget-frame.jimu-container * {
color: #ffffff !important;
outline: none;
}which causes strange behavior of our own color css styling:
If we remove the * and !important it looks like this:
Dart Theme is the only one causing problems like this. What can we (or ESRI) do about this?
Thanks in advance for your answer!
Gijs,
So in your code for your toolbar at the bottom of the widget you need to have a css rule with higher specificity that will use !important to override the
.jimu-widget-frame.jimu-container *So hopefully your toolbar as a class applied to it and you can just add a rule to it
This is not just copy and paste code, it is just an example of a higher specificity css rule.
.jimu-widget-frame.jimu-container .mytoolbar.button {
color: green !important;
Robert Scheitlin, GISP, I have a similar question. Is it possible to completely remove the container so my text is black and hyperlinks will be blue?
Sure you would just set the containers background color to a color with 0 opacity.
.blahblah {
background-color:rgba(0,0,0,0);
