WAB Updates
4675
06-01-2015 09:05 AM
JeffWard
Honored Contributor
So I am in the process of customizing the stemapp in the Web Appbuilder.  What happens when there is a WAB update?  Do I have to do it all again?
I am documenting the process, but would really rather not make all of these changes again.
Jeff
Jeff Ward
Summit County, Utah
RobertScheitlin__GISP
Jeff,
   Unless you add your WAB to some version control like GitHub or something, then yes you would need to redo them each release. I don't have not added WAB to any source control yet but I have seen some threads on this previously.
JunshanLiu
If you change code other then create your own custom widget/theme, I think you need to do it again if you get a new release.
