WAB - prevent in panel widget openAtStart on mobile
964
10-10-2019 01:02 PM
MaximeDemers
Hello,
I would like to disable the openAtStart config for a in panel widget on mobile device. I know in config.json there is a mobileLayout section but it seems to not work for widget that are in a widgetPool.
This the part of my config.json where the widget is defined:
"widgetPool": {
    "panel": {
      "uri": "themes/LaunchpadTheme/panels/LaunchpadPanel/Panel",
      "position": {
        "relativeTo": "map"
    "widgets": [
        "name": "LayerList",
        "version": "2.13",
        "uri": "widgets/LayerList/Widget",
        "config": "configs/LayerList/config_widgets_LayerList_Widget_41.json",
        "index": 1,
        "id": "widgets_LayerList_Widget_41",
        "label": "Liste de toutes les couches",
        "openAtStart": true
I know I could modify the widget.js to close it automatically if jimuUtils.inMobilieSize(), but that's not what I am trying to achieve. I would like to prevent the openAtStart completely.
Thank you!
RobertScheitlin__GISP
Maxime,
  I only did limited testing but if you make this change to the BaseLayoutManager.js. It worked for me.
      if(!this.openAtStartWidget && widgetConfig.openAtStart){
        if(!jimuUtils.inMobileSize()){
          iconDijit.switchToOpen();
          this.openAtStartWidget = widgetConfig.name;
Maxime,
