WAB Near Me Widget
8325
23
07-21-2016 10:35 AM
Fahad_Dalbouh
Good Afternoon All,
I Have a question about NearMe widge. After, the Near Me Widget reports the list of features within it's buffer distance, I decided to move to another widget, but the buffere and the symbols still floats and I couldn't know how to trurn them off.
Is it possible to control them on the widget configuratio.
Any help is appreciated.
DavidColey
MVP Frequent Contributor
Ok thanks for that - helps my understanding.  I believe I will have to add the snippet the the onClose event for the panel as well in order to handle the interactive cases
ElisabethvanderLeeuw
Hello (Robert / Fadhad),
In the AGOL Version - I can clear the results using the X in the search an address or locate on map - however, the X will not clear the graphics/result set on the Map.  As a user when I try to work with the original layer (I want to see all available features) I cannot, I can only work with the last results set.
Other than adding the code above to a WAB developer version is the AGOL version going to have a work around soon ??
thank you.
LindsayThomas
Hi Elisabeth,
Yes, this is an issue in Near Me and we have fixed it. We have added the ability to clear the widget results\graphics in the next release by 1) using the "X" button in the Search dialog and 2) clearning the results\graphics when the widget is closed.
This fix will be available in the Web AppBuilder for ArcGIS in the September 2016 Release and it will be available in the next version of Web AppBuilder (Developer Edition) 2.2 .
-Lindsay
FahadDalbouh
Hello Elisabeth,
You are right, this does not clear the graphics set on the map. I'm not sure if ESRI has planned to update this widget with the code above in AGOL version. I hope they are going to do that soon.
Thank you.
