WAB Dev Edition deployment... fail.
5766
11
10-22-2015 12:05 PM
RoyceSimpson
I've got the latest WAB Dev Edition on my local pc.  I've created an app that consumes this web map.  The web map is fully open/public but only has two layers, which are secured within our on premises AGS using Windows AD authentication.
When I edit the WAB app and or launch it within my local dev env, everything works great.  The app comes up, I authenticate against our AD and I get right in and can start editing those layers.
When I deploy the app to our external facing web server, the app hangs upon loading.
I have a second, none editable WAB app deployed on that same web server. It works just fine​.
I'm assuming the issue is with those editable/secured layers.  I've gotten esri feedback that I need to go the "proxy server" route but that doesn't make sense.  I don't want my users to bypass our AD security. I want them to have to authenticate against those AGS layers.  There is no AGOL login/named user needed as this map is public.  Perhaps I don't understand the concept of the proxy server.
Thoughts?
-Royce
RobertScheitlin__GISP
Royce,
   Not quite that complicated. Just change the proxy url when you copy the config.json over to the production web server.
RoyceSimpson
Gotcha, that's not too painful.  Thanks for the help!!!
