WAB 2.1 Add Data Widget Quirks
7885
16
08-12-2016 11:24 AM
DavidColey
MVP Frequent Contributor
Hi -  In exploring how to best work with the Add Data widget, I've noticed 2 issues:
Labels: for a feaure service, webmap confgured labels do not seem to load when added.  For example I have a zoning layer in a planning data wab that has labels configured.  The labels do not come over as part of the service when I add to another wab.
Popups: for an image service, the configured popup does not display, only the REST folder/servicename is shown in the popup.  For example, I have a high-resolution local DEM with configured and enabled popup, but it will not display either the
{Raster.ServicePixelValue} or {Raster.ServicePixelValue.Raw} values.
I'm guessing these are issues that would have to be resolved in the next release, just wondering if anyone else has encountered them.
David
Tags (1)
DavidColey
Yes Kevin thanks I am doing that already.  I am getting pixel value returns in my configured popup from the DEM dynamic image service in my webmap from my dynamic image service, e.g.
Surface Height: <b>{Raster.ServicePixelValue.Raw} FT</b>
I haven't actually explored adding my DEM service to one of my api apps but I think this would still work
JamesCrandall
Edit: I goofed and applied the suggested changes to the wrong app, this does fix the issue!  Sorry for that.
I've implemented the recommended modifications to an app in WAB Developer 2.5 but the popup still does not show field information.
DavidColey
I've now been able to make the change at 2.6 and am getting my popup info for my dem values.  You sure you've got everything set in your webmap?
JamesCrandall
The web map does not contain the DEM.  We are adding it to the WAB application from the AddData widget but it doesn't display the popup information.
DavidColey
Sorry, I meant as far as the layer popup's configuration settings, i.e. in my reply to Kevin earlier. Sounds like you have.
JamesCrandall
It was my mistake.  I applied the suggested changes to the wrong app (WAB Developer 2.5).
DavidColey
ok good to know
