Update LayerList Widget in response to layer visibility changes
6500
01-02-2015 01:30 PM
MaxMcCosham
Hello,
I was wondering if it is possible to configure the LayerList Widget to update/refresh in response to layer visibility changes. I currently have programmed the Query Widget to toggle the visibility of ArcGIS Online web map layers based on query results. The LayerList Widget correctly shows which layers are visible when the widget is opened for the first time. It will also update with any layers that are added or removed using the Query Widget. If the LayerList has already been opened, visibility changes are not reflected in the list (For example, if Layer 1 is hidden and Layer 2 is set to visible, Layer 1 is still left checked in the list of layers). Does the LayerList Widget have to be modified to listen for layer visibility changes after it has been opened?
Max
Tags (3)
LemaoWu
Hi Max,
This is not supported in Layer List widget currently. It's a known issue. Hope it can be fixed ASAP.
shanmuga_sundaramMasanam
Hi
Any one have some details? I am also looking for same..
RobertScheitlin__GISP
Max,
   You need to contact esri tech support and enter an enhancement request.
RomanChueh
Max,
I am having a similar issue, have you had any luck finding a solution for it?
LemaoWu
Hi Max,
MaxMcCosham
Thanks for the update! I ended up proceeding without using the layer list widget, but will watch for any changes in the next version.
