Time field in Pop-up
5611
11
04-20-2016 05:55 AM
LianaSmith
I have a layer with a data that updates every 15 minutes. In my Web Map and Web Application the time field shows time that is 4 hours earlier than the time that I see in Arc Map (So it shows it in a different time zone).
How can I use the same time zone that I have in Arc Map?
I do not need Time Animation.
Tags (1)
LianaSmith
Thank you anyway for your help!!!
AbiDhakal
Hey Brian,
I'm late in the show, but I'm in the show now nonetheless.
I'm having issue with date on the web appbuilder application versus the GIS Server date.
The date field for the  feature service in the web appbuilder is not matching with the date field for the same feature layer for the same field on the Server. Pretty much what you are referring to in your message above.
I do not have the advantage of create a new field and running the time zone conversion geoprocessing tool. My data is directly being fed to another system once I copy the layer from the Server. So, I can only copy the erroneous layer.
A day in the data is making a lot of difference. Especially, for a new fiscal year date. I'm trying to put in 10/1/2018 for the start of a new fiscal year in the feature service in my web appbuilder, but the data on the Server is showing up as 9/30/2018, and for this reason any data that is being generated on 10/1/2018 is not being included in the current fiscal year. Has this problem been resolved? What is the workaround?
Thank you for your help.
Abi
