this.sceneView.hitTest(screenPoint): Uncaught TypeError
1721
02-09-2017 03:11 PM
by Anonymous User
Not applicable
I created a small application using JavaScript API 4.2 (3D) which works fine.  Now, I am trying to replicate the same within WAB.  However, I have a problem executing sceneView.hitTest() function.  it gave me an "Uncaught TypeError".  I am new to WAB so I can't figure out what I am doing wrong.  I would greatly appreciate any inputs.
Here is the error I am getting and code.
onOpen: function(){
   console.log('onOpen');
   this.sceneView.on("click", function(event){
        var screenPoint = {x: event.x, y: event.y};
        console.log(screenPoint);
        this.sceneView.hitTest(screenPoint).then(function(res){
           console.log(res.results[0]);
Thank you,
Makiko
RobertScheitlin__GISP
Makiko,
  Your issue is the scope of "this" has changed inside your sceneView click event handler. So to get past that you need to use lang.hitch:
onOpen: function(){
   this.sceneView.on("click", lang.hitch(this, function(event){
Makiko,
onOpen: function(){
by Anonymous User
Not applicable
Robert,
Learning lang.hitch is game changing!! Thank you so much!!
