summarize by polygon in ArcGIS Online webapp
8320
14
05-02-2017 07:06 AM
deleted-user-3QvhwBivZdaR
I would like to add a widget to my Web App Builder based AGOL app, which can return a summary of points within a polygon from another layer.  Can this be done?
I dont want anything that has prebuilt summaries.  The Info Summary tool looks close, but it looks like it only return the sum of the features within the current map extent.  Is there a away to use this so I can get a summary within the bounds of a polygon feature? So far I haven't had any luck figuring this out.
Thanks, Jason
DrewMerrill1
Hey Jason,
Did you ever find a solution for summarizing points within a polygon besides the analysis widget? I am having a similar issue.
Thanks.
AnaHiraldo-Gomez
Have the same question - any solution?
DougBrowning
MVP Esteemed Contributor
Bump again.  Selections are the heart of ArcMap.  So weird that AGOL does not use them at all.
DavidLight
Same need - Need a widget to select polygons within another polygon.
DariusMirdamadi1
I believe you can use the 'situation awareness' widget. This way you can summarise using a custom polygon.
