Start Query (widget) Results as Collapsed
852
03-24-2021 08:11 AM
MikeWeiner
Even with the option unchecked, the query results always show up as expanded.  We used the solution for insuring the icon shows the correct Expand/Collapse but that does nothing for the results.  We use queries that might return multiple results and having them start as collapsed would allow the user to better find the correct result before expanding it.  If it involves changing the widget code, could you include which .js file needs the edit?  I found four copies of SingleQueryResults.js and applied the fix to all four.  Yes, I am fairly new to web appbuilder.
