Smart Editor populate field with default value
7605
14
05-11-2021 08:23 AM
JoseSanchez
Hello everyone,
I am using Smaprt Editors with WAB in Portal.
I am looking for a way to populate a field with the value "No", before the editors starts editing.
Also I would like to disable edits in this same field and predefide its value to "No".
How can I do that?
Thanks
DavidPike
MVP Notable Contributor
The smart edit widget should provide all of this
Smart Editor widget—ArcGIS Web AppBuilder | Documentation
has info on setting default values, and I believe the smart edit widget has checkboxes for editable fields.
If you want to set up a more complex data structure with preset field values/dropdowns etc. you should probably look at Subtypes and Domains Introduction to attribute domains—ArcGIS Pro | Documentation
JoseSanchez
Found it. Thank you.
Under General setting, there is a button called "Defined Preset"
VincentRobinson
Hi , I created a new field and set the default value to "new", with that being said whenever I use the smart editor widget for some reason it will not populate this field with "new" while I'm in the app . but it will populate this value in a plain web map just fine. I tried the general settings ,and I couldn't  any thing that works , can some one help me with this?
AlixVezina
Hi Vincent,
Perhaps try using a Preset from the Attribute Action tab in the Smart Editor widget setting?
You can set the value "new" for that field and it will be filled out automatically with that value when you create a new feature.
VincentRobinson
thanks for the quick reply, I did try this but it didn't work, or maybe I've misunderstood how it works.
AlixVezina
Is this in ArcGIS Online? Are you able to share your web application so I can take a look? You can share it with me through a group, my username is AlixSolutions.
VincentRobinson
its on our portal.
AlixVezina
Are you using Web AppBuilder from your Portal edition, which version are you on? Or are you using a version of Web AppBuilder developer edition?
VincentRobinson
Web AppBuilder Portal edition.
