Smart Editor create polygon from long/lat
1675
12-18-2023 01:16 AM
Labels (2)
nabaz-gharib
Hi All,
I have a question, appreciate if someone have a solution.
My question is how to create a polygon from smart editor using long/lat s ? you can create polygon by clicking on the map, but I want to add long/lat manually.
This feature is available for point layer, you can add point by long/lat, but I cannot see this feature for polygon.
Amir-Sarrafzadeh-Arasi
Dear nabaz,
Maybe this will solve this issue,
Please check the attached files .
There are 1 python script, and a json data with sample polygons, and finally you should see the attached result image all in the attachment zip file.
If you need more clarification please let me know.
Best Regards
Amir Sarrafzadeh Arasi
nabaz-gharib
thank you for your reply,
your solution is useful if I wanted to add multipoint from ArcGIS pro.
But I want to create polygon by manually entering points from smart editor widget.
JosiahMillar
Did you ever figure this out?
Nabaz_Gharib
Unfortunately No, we used geocortex to create polygon using points.
