Smart Editor change alias name of attributes
2064
01-12-2021 08:48 AM
AFackler_NAPSG
I am trying to change the alias of an attribute field in Smart Editor, in this case, to make Address into Full Address. I read around that you can just double click and change it, but I can't get it to work. Am I missing something or is this not even possible? Thanks
AlixVezina
Hi @AFackler_NAPSG ,
As @SethLewis1 said above, this capability is not available in Smart Editor, you will need to make the change in the web map pop-up configuration or in the feature layer item settings.
SethLewis1
Try changing the field alias in the supporting webmap. That change should be reflected when you re-load the application.
AlixVezina
