Screen Widget not responding in ArcGIS Web AppBuilder - ArcGIS Enterprise 11.4
1380
02-28-2025 07:22 AM
AbiDhakal
Hello GIS friends,
Good morning, and happy Friday!
I’m currently running ArcGIS Enterprise 11.4 and am experiencing an issue with the Screening widget in my Web AppBuilder. Specifically, I’m unable to configure the widget—it remains unresponsive. After I click to add the widget and navigate to the Analysis tab, when I attempt to add layers, nothing happens.
I’ve been using this widget in my Web AppBuilder for years without any issues, but this morning when I tried to work on it, the widget stalled. I thought it might need to be reconfigured, but when I attempted to do so, it remained unresponsive. Interestingly, the widget works fine in ArcGIS Online, but not in my Enterprise environment.
Any assistance or suggestions would be greatly appreciated.
Thank you so much,
Abi
AbiDhakal
Dear GIS Friends,
I hope you're all doing well. I’ve identified the issue, but I need some assistance in resolving it. As you may recall, the 'Regrid_Nationwide_Parcel_Boundaries_v1' layer that Esri introduced to us this past summer is the reason why the Screening widget does not function properly when that layer is added to the map.
Could I kindly ask for your help in getting this to work?
Thank you so much to this incredible community for your continued support.
Best regards,
Abi
SATYASREEANNAMNEEDI
I am also facing the same issue but in Enterprise 11.1.
jcokin1
This issue is still present in 11.5 Enterprise Deployment as well. @AbiDhakal Has there been any other resolution to get this to work?
