Repair data source in web map / web app
2141
01-03-2023 01:58 PM
Veronicampbell
Is there a way to repair a broken data source within a web map? I know you can right click to open properties and reroute the source, but I'm not finding this capability for web maps. It's only an issue because I've already configured all of the symbology, labelling, extent, attribute filters, and popup, and would have to redo all of this if I were to add in the new source from scratch. A copy/paste capability for symbology and other configurable items might be nice.
CarmelConnolly
Hi Veronica,
You can find webmaps in your organisation by changing the search parameters through the search box drop down arrow:
I can't think of another way of doing it out of the box without having to redo all your layer configuration.
DougGreen
Yes there is. The ArcGIS Online Assistant has tools to do this as well as view and modify JSON. Hope that helps.
Veronicampbell
Thanks, is there any other way to update sources besides this? I have privileges to edit the web map but am not the owner anymore, so I wasn't able to locate it in ArcGIS Online Assistant. I wonder if there is a reason for not having the same capability as ArcMap/Pro to update sources within a properties/settings tab?
CarmelConnolly
Hi Veronica,
