Python Scripting Error Export Layout
2611
11-09-2020 07:19 AM
ConnorBerry
Good morning! I am using ARCGIS Pro v2.3 to develop a web tool, part of which exports pdf to a created directory on our server. While the script runs perfectly in arcgis Pro, when I publish it as a web tool I receive OS Error: (path.) This error occurs on the line lyt.ExportToPDF (path.) The path is dynamic, in the sense that a new folder is created in the directory each time, and changes each time the script is run. Additionally, I am able to write other files to the path, just not the pdf. I have tried changing paths, taking away transparency on the maps themselves, creating the pdf document before the output, etc. I am just so lost on this and would love some help/ideas. It makes no sense to me as well because the script runs perfectly up until I publish it as a web tool. Thanks!
Tags (4)
DavidPike
MVP Notable Contributor
Is the parent directory registered to the ArcGIS server, and is it an FQDN or drive mapped path?
Can you share the script?
ConnorBerry
Yes, the parent directory is registered and I believe it is a drive mapped path (though I am fairly new in this area so am not entirely sure.) I am unable to share the full script, but here are the parts I can share were it errors at
output_workspace = arcpy.GetParameterAsText(0) #folder
geodatabase_name = arcpy.GetParameterAsText(1) #string
os.mkdir(output_workspace + '//' + geodatabase_name)
output_workspace = output_workspace + '//' + geodatabase_name
def create_new_constraints_pdf(output_workspace, geodatabase_name, output_geodatabase):
aprx = arcpy.mp.ArcGISProject(path to aprx) #aprx gets copied to web tool
arcpy.env.workspace = output_geodatabase
map = aprx.listMaps()[0]
constraints_lyr = output_workspace + '//' + 'constraints' + '.Lyrx'
lyrFile = arcpy.mp.LayerFile(constraints_lyr)
lyt = aprx.listLayouts()[0]
legend = lyt.listElements("LEGEND_ELEMENT")[0] #Calls Legend Element
legend.syncNewLayer = True #Makes all newly added layers appear in legend
map.addLayer(lyrFile, 'Top')
for lyr in map.listLayers(): #For statement will properly color layers on map
if lyr.isFeatureLayer:
sym = lyr.symbology
if hasattr(sym, 'renderer'):
if sym.renderer.type == 'SimpleRenderer':
sym.updateRenderer('GraduatedColorsRenderer')
sym.renderer.classificationField = "total_score"
sym.renderer.breakCount = 5
lyr.symbology = sym
lyr = map.listLayers()[0]
lyr.transparency = 20 #Sets transparency to 20%
legend.syncLayerVisibility = True #Places all layers on map into legend
lyt.exportToPDF(output_workspace + '//' + 'transparent') #(Errors out here)
map.clearSelection()
DavidPike
try an os.path.join instead of concatenation on
also are you missing the .pdf in the filename?
The syntax highlighter would make this much more readable to others.
TanuHoque
@ConnorBerry
Quick question: what version of ArcGIS Server you are running your service?
