Programmatically filter attribute table
12115
24
06-17-2016 02:39 PM
Ravichandran_M_Kaushika
dear Readers,
thank you for taking the time to read the contents of the post.
How to programmatically filter records of the attribute grid?
there is a filter menu that open a popup window which allows the users to select the column by which the condition should be applied.  it also provides the ability to add 1 or 2 more columns with the option to make it ANY or AND.\
Is there a way to perform this operation programmatically?
thanks and regards
ravi.
friskyweasel
Thanks a lot for the quick reply Robert - yes in retrospect I guess that should have been pretty obvious ; ). We will definitely try it - thanks a bunch for all of your help!
RebeccaStrauch__GISP
fyi Robert, you text says "1=1", your sample code says "1-1".  Might want to fix which ever is incorrect (assuming is should be 1=1)
RobertScheitlin__GISP
Thanks Rebecca.
friskyweasel
worked beautifully Robert - thanks a lot!
Sorry Robert,
my colleague Mark (Frisky Weasel) was working on this issue and I forgot to check back.
have a good weekend.
regards
ravi.
