Outfields in Search Widget (WAB)
1142
05-11-2018 09:45 AM
Carlos_ArturoSarmiento_Royero
I am using the wab search widget with multiple sources, but it is skipping the field of outfields. Thanks
"allPlaceholder": "",
"showInfoWindowOnSelect": true,
"sources": [
"url": "https://services1.arcgis.com/MUGZBRzuQOwSq7Du/ArcGIS/rest/services/Limites/FeatureServer/0",
"name": "Departamentos",
"placeholder": "Atlántico",
"searchFields": [
"cod_dpto",
"dpto"
"outFields": [
"cod_dpto",
"dpto",
"acto",
"anno"
"displayField": "dpto",
"exactMatch": false,
"searchInCurrentMapExtent": false,
"zoomScale": 50000,
"maxSuggestions": 6,
"maxResults": 6,
"type": "query",
"highlightSymbol": {
"color": [
255,
0,
0,
128
"outline": {
"color": [
0,
166,
81,
255
"width": 1,
"type": "esriSLS",
"style": "esriSLSSolid"
"type": "esriSFS",
"style": "esriSFSSolid"
RobertScheitlin__GISP
Carlos,
   The widget is hard coded to use all fields as the sources outFields property. You should have noticed that there was no widget setting for specifying the outFields. You would have to adjust code in the Widget.js to allow for specifying a select array of outFields.
Carlos,
