Not expected behavior when I cut polygon in WAB
3382
08-13-2015 10:39 AM
DiegoLlamas
Hi.
I’m using the editing widget of the WebApp Builder to edit polygons and have encountered some strange behavior. I have 2 examples.
1. I select a parcel using selection tool
I use Cut/split tool to separate the parcel selected in 3 parts.  I split using the graphic below,
The tool also splits the polygon right next to the selected one even though it’s not selected and create a new polygon, polygon that I do not want that's why I didnot select the parcel.
2. While splitting a multi part polygon the tool generates multi part polygons instead of individual polygons.
In this example I split the multi-part polygon by drawing a road that goes through the parcel. When I finished it created the two multi-part polygon. The one in the image above and the one in the image below.
So, I wild like to know if this is how it was design or if it’s a bug.
Diego Llamas
MichaelBerzinis
That definitely is not the behavior one experiences in desktop.  Does it happen now--seems like this may have been fixed?
