Need help! Embedded map stopped loading!
966
07-25-2021 07:15 PM
sr_guy
I created an arcgis map to lookup power company data for my dept to use to easily lookup power outages by address. I changed the basemap layer to an OpenSteetmaps variation, and now all of a sudden the stormap won't load when embedded:
Storyline direct URL:
https://www.arcgis.com/apps/instant/lookup/index.html?appid=f0925351adef4e178ce241f4c56dcf63
Embedded:
<iframe src="\[https://www.arcgis.com/apps/instant/lookup/index.html?appid=f0925351adef4e178ce241f4c56dcf63\](https://www.arcgis.com/apps/instant/lookup/index.html?appid=f0925351adef4e178ce241f4c56dcf63)" width="1300" height="750" frameborder="0" style="border:0" allowfullscreen>iFrames are not supported on this page.</iframe>
Map is being shared as " Everyone (public)".
When the embedded map tries to load it displays an error " www.arcgis.com refused to connect. "
Has anyone had a simular issue like this? If so, is there a solution?
sr_guy
I think I fixed it. I'm not sure why it worked, but it did.
1. I set this layer 'Recent Weather Radar Imagery '(by NOAA GeoPlatform) as a base map instead of one of the other arcgis defaults
2. And then added, Electric Retail Service Territories ( by SGT_Peterson) a layer (layer that contains all the power company data), and all of a sudden everything started working. I'm not 100% why that worked though.
