Near Me Widget: Slider Interval Issue
1174
12-01-2017 01:38 PM
DavidColey
MVP Frequent Contributor
Hi all -
So I've noticed a buggy behavior with the distance slider intervals on the Near Me widget since probably WAB 2.4.  Seems that the slider interval doesn't honor the second interval unit.  For example, if I set a max distance of 5, units miles, the slider will show 1, 3, 4, 5 skipping mile 2.  Changing units or distances doesn't seem to matter.  Maybe there's something that can be added to intermediateChanges property in the _createSlider function?
 * This function create horizontal slider and set minimum maximum value of slider
 * @memberOf widgets/NearMe/Widget
 _createSlider: function () {
 // initialize and set the parameter of slider
 this._slider = new HorizontalSlider({
 discreteValues: this.config.maxBufferDistance,
 minimum: 0,
 maximum: this.config.maxBufferDistance,
 value: this.config.defaultBufferDistance,
 intermediateChanges: true,
 "class": "esriCTHorizantalSlider"
 }, this.horizantalSliderContainer);
 this._bufferParams = {
 BufferDistance: this._slider.value.toString(),
 BufferUnit: this.nls.units[this.config.bufferDistanceUnit.value].displayText
 // set slider content
 domAttr.set(this.silderText, "innerHTML", string.substitute(
 this.nls.bufferSliderText, this._bufferParams));
 // on change event of slider
 this.own(this._slider.on("change", lang.hitch(this, this._sliderChange)));
 // set maximum and minimum value of horizontal slider
 this.sliderMinValue.innerHTML = this._slider.minimum.toString();
 this.sliderMaxValue.innerHTML = this._slider.maximum.toString();
David
Tags (1)
RobertScheitlin__GISP
David,
   The slider steps are decided by the min, max and discreteValues properties if the discreteValues is 3 then the slider will have a minimum a maximum and one value in the middle of those ranges. So is the this.config.maxBufferDistance and the slider length are what really controls the the slider steps. Try adjusting the maxBufferDistance.
DavidColey
Yeah I tried several different maxBufferDistance settings. So far, a middle value is always skipped.  If set to 11, value 6 is skipped.  If set to 10, value 5, etc.  Not sure if this is the case with the online WAB
DavidColey
Yes the behavior is the same for the online version as well
